주요 콘텐츠로 건너뛰기
Olympus FE-170 Flash Assembly Replacement
필요한 것
  1. Olympus FE-170 Flash Assembly Replacement, Casing: 1 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement, Casing: 1 단계, 이미지 2/2
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Olympus FE-170 Flash Assembly Replacement: 2 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 2 단계, 이미지 2/2
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Olympus FE-170 Flash Assembly Replacement: 3 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Olympus FE-170 Flash Assembly Replacement: 4 단계, 이미지 1/1
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Olympus FE-170 Flash Assembly Replacement: 5 단계, 이미지 1/1
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Olympus FE-170 Flash Assembly Replacement: 6 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 6 단계, 이미지 2/2
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Olympus FE-170 Flash Assembly Replacement: 7 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 7 단계, 이미지 2/2
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Olympus FE-170 Flash Assembly Replacement: 8 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 8 단계, 이미지 2/2
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
  9. Olympus FE-170 Flash Assembly Replacement, Flash Assembly: 9 단계, 이미지 1/3 Olympus FE-170 Flash Assembly Replacement, Flash Assembly: 9 단계, 이미지 2/3 Olympus FE-170 Flash Assembly Replacement, Flash Assembly: 9 단계, 이미지 3/3
    • Remove the two small screws on the top of the flash itself.
  10. Olympus FE-170 Flash Assembly Replacement: 10 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 10 단계, 이미지 2/2
    • Use the spudger to gently pry the top of the thin metal casing around the flash loose.
  11. Olympus FE-170 Flash Assembly Replacement: 11 단계, 이미지 1/1
    • Use the spudger to gently pry the bottom of the thin metal casing around the flash loose.
  12. Olympus FE-170 Flash Assembly Replacement: 12 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 12 단계, 이미지 2/2
    • Use your fingers to gently pull the metal casing off of the flash.
    • Remove the plastic flash diffuser by gently prying at the edges with your fingers.
  13. Olympus FE-170 Flash Assembly Replacement: 13 단계, 이미지 1/2 Olympus FE-170 Flash Assembly Replacement: 13 단계, 이미지 2/2
    • Remove the screw holding the flash circuit board in place.
  14. Olympus FE-170 Flash Assembly Replacement: 14 단계, 이미지 1/1
    • Pull the flash-bulb sub-assembly out of its place by using the pointed end of the spudger.
  15. Olympus FE-170 Flash Assembly Replacement: 15 단계, 이미지 1/3 Olympus FE-170 Flash Assembly Replacement: 15 단계, 이미지 2/3 Olympus FE-170 Flash Assembly Replacement: 15 단계, 이미지 3/3
    • Use the pointed end of the spudger to pull up both layers of tape on top of the flash-bulb sub-assembly.
    • Remove the wire layered in between the two sections of tape from the flash-bulb sub-assembly.
  16. Olympus FE-170 Flash Assembly Replacement: 16 단계, 이미지 1/1
    • Pull the flash circuit board and flash-bulb sub-assembly off from the front of the camera.
  17. Olympus FE-170 Flash Assembly Replacement: 17 단계, 이미지 1/3 Olympus FE-170 Flash Assembly Replacement: 17 단계, 이미지 2/3 Olympus FE-170 Flash Assembly Replacement: 17 단계, 이미지 3/3
    • Use the spudger to push the black capacitor out from its slot.
    • Remove the entire flash assembly by gently pulling outward and away from the camera.
결론
Tyler Hartwig
회원 가입일: 03/24/15
337 평판
안내서 3개 작성하였습니다
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 회원
BU-SHAVER-S15S6G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 266
