주요 콘텐츠로 건너뛰기
Olympus FE-170 LCD Screen Replacement
필요한 것
  1. Olympus FE-170 LCD Screen Replacement, Casing: 1 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement, Casing: 1 단계, 이미지 2개 중 2개
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Olympus FE-170 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Olympus FE-170 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Olympus FE-170 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Olympus FE-170 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Olympus FE-170 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Olympus FE-170 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Olympus FE-170 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
  9. Olympus FE-170 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3개 중 1개 Olympus FE-170 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3개 중 2개 Olympus FE-170 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3개 중 3개
    • Remove the three screws holding the LCD Screen in place.
    • The screws are located at the upper right, upper left, and lower left corners of the screen, as shown in the pictures.
    • After removing the screws, do not let the screen drop away or try to pull it out. It is still connected by a ribbon of wires.
  10. Olympus FE-170 LCD Screen Replacement: 10 단계, 이미지 3개 중 1개 Olympus FE-170 LCD Screen Replacement: 10 단계, 이미지 3개 중 2개 Olympus FE-170 LCD Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully lift the LCD screen away
    • Don't pull away. The ribbon will still be connected to the camera.
  11. Olympus FE-170 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Olympus FE-170 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, lift the latch on the ribbon connector.
    • Insert the plastic opening tool beneath the latch, and gently pull up.
    • Carefully pull the ribbon out, and lift the LCD screen out and away.
결론
작성자
2다른 기여자 명과 함께
Who Knows?
회원 가입일: 03/24/15
104 평판
안내서 1개를 작성함
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 회원
BU-SHAVER-S15S6G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 985
