주요 콘텐츠로 건너뛰기
Olympus OM-D E-M10 Mark II Motherboard Replacement
필요한 것
  1. Olympus OM-D E-M10 Mark II  Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II  Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II  Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove eight screws using a Phillips #00 screwdriver.
    • There are 3 different screws, (2x) 3 mm, (3x) 2.5 mm, (3x) 4 mm.
  3. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the bottom cover off the camera.
  4. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using the Phillips #00 remove two 5.0 mm screws, one from each side of the base of the camera.
  5. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the camera over until it is laying on its backside. Open the screen until it fully extended and perpendicular as shown below. Remove the three screws located there with the Phillips #00.
    • There are two different types of screws. (2x) 2.7 mm, (1x) 3.5 mm.
  6. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Turn the camera over on its side as shown. There is a small compartment door that has a screw located underneath it. Remove the 2.5 mm screw with a Phillips #00 screwdriver.
  7. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II  Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Take the front and back of the camera apart.
    • Be careful when taking the front and back of the camera apart because there are connecters to the motherboard from both halves which are very fragile. In order to fully take the two halves apart you will need to unhook the connectors from the motherboard.
  8. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Position the front half as depicted below. The motherboard is the green computer chip on the right half the picture below. You will need to disconnect everything from the motherboard. Gently pull out all orange connectors.
  9. Olympus OM-D E-M10 Mark II  Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Using a Phillips #00 remove the three 3.0 mm screws while holding the motherboard in place. You should then be able to gently remove the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Connor Langguth
회원 가입일: 09/03/19
379 평판
안내서 2개를 작성함
IUPUI, Team S1-G5, Hovde Fall 2019 IUPUI, Team S1-G5, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G5
3 회원들
안내서 8개를 작성함
2가이드 댓글
Good work! My anode selector does not work, I am stuck in AUTO, mines mark iii but looks very similar. Anyone else has this issue?
Phil Rydin - 답글
This is what Olympus had to say about me replacing the mother board- what are your thoughts. The issue is indeed in the mainboard. However, we don't sell that part and even if you buy it elsewhere, for it to work properly, it will have to be configured with specific codes that only we have and that, as you must understand, are confidential, so, in this case, we suggest that you proceed with the repair.
Dan Ingersoll - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 143
전체 시간: 6,319
