주요 콘텐츠로 건너뛰기
Olympus OM-D E-M10 Mark II Battery Replacement
  1. Olympus OM-D E-M10 Mark II Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Open the battery door latch by moving the black button in the direction of the arrow, towards the camera screen.
    • To ensure that the battery door is properly in the closed position, listen for an audible click.
  2. Olympus OM-D E-M10 Mark II Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Move the dark red latch towards the direction of the camera lens to release the battery from the camera.
    • Make sure the dark red latch blocks the battery from moving after placing the battery in the camera during reassembly.
  3. Olympus OM-D E-M10 Mark II Battery Replacement: 3 단계, 이미지 1개 중 1개
    • You can now remove the battery from the body of the camera and begin reassembly with your new battery.
결론
To reassemble your device with your new battery, follow these instructions in reverse order.
작성자
2다른 기여자 명과 함께
Allen Anjal
회원 가입일: 09/27/16
341 평판
안내서 2개를 작성함
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G6
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 115
전체 시간: 6,971
