주요 콘텐츠로 건너뛰기
Olympus OM-D E-M10 Mark II Flash Replacement
필요한 것
  1. Olympus OM-D E-M10 Mark II Flash Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II Flash Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II Flash Replacement: 2 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II Flash Replacement: 2 단계, 이미지 2개 중 2개
    • Remove eight screws using a Phillips #00 screwdriver.
    • There are 3 different screws, (2x) 3 mm, (3x) 2.5 mm, (3x) 4 mm.
  3. Olympus OM-D E-M10 Mark II Flash Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the bottom cover off the camera.
  4. Olympus OM-D E-M10 Mark II Flash Replacement: 4 단계, 이미지 1개 중 1개
    • Using the Phillips #00 remove two 5.0 mm screws, one from each side of the base of the camera.
  5. Olympus OM-D E-M10 Mark II Flash Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the camera over until it is laying on its backside. Open the screen until it fully extended and perpendicular as shown below. Remove the three screws located there with the Phillips #00.
    • There are two different types of screws. (2x) 2.7 mm, (1x) 3.5 mm.
  6. Olympus OM-D E-M10 Mark II Flash Replacement: 6 단계, 이미지 1개 중 1개
    • Turn the camera over on its side as shown. There is a small compartment door that has a screw located underneath it. Remove the 2.5 mm screw with a Phillips #00 screwdriver.
  7. Olympus OM-D E-M10 Mark II Flash Replacement: 7 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II Flash Replacement: 7 단계, 이미지 2개 중 2개
    • Take the front and back of the camera apart.
    • Be careful when taking the front and back of the camera apart because there are connecters to the motherboard from both halves which are very fragile. In order to fully take the two halves apart you will need to unhook the connectors from the motherboard.
  8. Olympus OM-D E-M10 Mark II Flash Replacement: 8 단계, 이미지 1개 중 1개
    • Position the front half as depicted below. The motherboard is the green computer chip on the right half the picture below. You will need to disconnect everything from the motherboard. Gently pull out all orange connectors.
  9. Olympus OM-D E-M10 Mark II Flash Replacement: 9 단계, 이미지 1개 중 1개
    • Using a Phillips #00 remove the three 3.0 mm screws while holding the motherboard in place. You should then be able to gently remove the motherboard.
  10. Olympus OM-D E-M10 Mark II Flash Replacement, Flash: 10 단계, 이미지 1개 중 1개
    • See the Olympus OM -D E-M10 Mark II guide for motherboard replacement and follow the guide until the motherboard is exposed
  11. Olympus OM-D E-M10 Mark II Flash Replacement: 11 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II Flash Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the +/- cover in the center of the dial by levering the small indent.
    • Remove the screw found below the cover.
  12. Olympus OM-D E-M10 Mark II Flash Replacement: 12 단계, 이미지 3개 중 1개 Olympus OM-D E-M10 Mark II Flash Replacement: 12 단계, 이미지 3개 중 2개 Olympus OM-D E-M10 Mark II Flash Replacement: 12 단계, 이미지 3개 중 3개
    • Remove three screws from the front casing of the viewfinder
    • Remove the front casing of the viewfinder, being mindful of any ribbons which may be connected to other components
  13. Olympus OM-D E-M10 Mark II Flash Replacement: 13 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II Flash Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the two screws on the front of flash component.
    • Remove the outer gray casing of the flash component by using a spudger to separate the black and gray plastic pieces.
    • Use a soldering iron to replace the broken component of the flash connected to the circuit board.
결론
작성자
2다른 기여자 명과 함께
Wyatt Highland
회원 가입일: 03/31/22
115 평판
안내서 1개를 작성함
IUPUI, Team 2-2, Harley Spring 2022 IUPUI, Team 2-2, Harley Spring 2022 회원
IUPUI-HARLEY-S22S2G2
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 836
