이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The HDMI Connector Door (also referred to as the connector cover) allows access to both of the camera's connector ports; the HDMI connector port and the multi-connector port. In order to keep the connectors protected from outside damage, the Connector Door needs to be intact. If the HDMI Connector Door has been damaged, you can use this guide to ensure you are properly removing and replacing it.
필요한 것
Using the PH00 Phillips-head screwdriver, unscrew the two 1/3 inch screws with silver threads from the the bottom of the camera.
Using the PH00 Phillips-head screwdriver, unscrew the three 1/3 inch screws with blue threads from the the bottom of the camera.
Using the PH00 Phillips-head screwdriver, unscrew the three 1/2 inch screws with silver threads from the the bottom of the camera.
To add your new HDMI connector door, follow these instructions in reverse order.
댓글 한 개
so, where can I buy the port cover or door for the OMD-em10 mark2? Thanks
