주요 콘텐츠로 건너뛰기
Olympus OM-D E-M10 Mark II Lens Replacement
  1. Olympus OM-D E-M10 Mark II Lens Replacement, Lens: 1 단계, 이미지 1개 중 1개
    • Press the black button located to the right of the camera lens when facing the front of the camera.
  2. Olympus OM-D E-M10 Mark II Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Grasp the innermost ring on the lens, closest to the camera body, which can be located by the small red dot. This is the only ring that should not turn, unless the button specified in the previous step is held down.
  3. Olympus OM-D E-M10 Mark II Lens Replacement: 3 단계, 이미지 1개 중 1개
    • While holding down the button specified in step 1, begin turning the inner most ring, specified in step 2, counterclockwise until the camera lens becomes free from the camera body.
  4. Olympus OM-D E-M10 Mark II Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Once the lens is free from the camera body, pull the lens completely away from the body to make sure the lens is truly free.
결론
작성자
2다른 기여자 명과 함께
Channing Pezet
회원 가입일: 02/14/18
214 평판
안내서 2개를 작성함
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G6
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 67
전체 시간: 4,495
