주요 콘텐츠로 건너뛰기
Olympus OM-D E-M10 Mark II Screen Replacement
필요한 것
  1. Olympus OM-D E-M10 Mark II Screen Replacement, Screen: 1 단계, 이미지 1/2 Olympus OM-D E-M10 Mark II Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II Screen Replacement: 2 단계, 이미지 1/1
    • Extend out the screen so you can reach the screws. Remove the a total of four screws using a Phillips #00 at the top and the back of the screen.
    • This step has two types of screws. (2x) 3.5 mm on the top, (2x) 1.7 mm on the back.
  3. Olympus OM-D E-M10 Mark II Screen Replacement: 3 단계, 이미지 1/1
    • Pull the screen away from the base of the camera. Then disconnect the cable connectors from the circuit board. Be sure to remove the smaller circuit board with care.
  4. Olympus OM-D E-M10 Mark II Screen Replacement: 4 단계, 이미지 1/1
    • Separate the screen from the camera. Now you are able to install your replacement screen
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Connor Langguth
회원 가입일: 09/03/19
346 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G5, Hovde Fall 2019 IUPUI, Team S1-G5, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 4개
Hi, do you know if the LCD screen from the Mark II is the exact same as the Mark III? I see replacements for the Mark II being sold, but they don’t say whether they’re compatible.
Solomon Krause-Imlach - 답글
Hey Solomon I am experiencing the same issue. Did you find out if they are exactly the same?? My LCD screen no longer functions and all I come across online is the Mark II LCD's.
Zacharia Gupta -
Hi, do you know where I can buy the screen?
Thanks
Lorenzo
Lorenzo Zaccarini - 답글
If you order only panel like me, theres few wery scary parts more. You have to remove couple pcb's, trying get connectors back in and you definetly need elastic glue for glueing screen back.
Mikko Hyvärinen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 52
30일 전: 221
전체 시간: 10,388
