소개
Use this guide to replace a damaged back case, or open the case to access other components of your camera.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
필요한 것
Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
1가이드 댓글
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - 답글
