주요 콘텐츠로 건너뛰기
Olympus Pen E-PL7 Back Case Replacement
필요한 것
  1. Olympus Pen E-PL7 Back Case Replacement, Back Case: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  2. Olympus Pen E-PL7 Back Case Replacement: 2 단계, 이미지 1/1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  3. Olympus Pen E-PL7 Back Case Replacement: 3 단계, 이미지 1/1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  4. Olympus Pen E-PL7 Back Case Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  5. Olympus Pen E-PL7 Back Case Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  6. Olympus Pen E-PL7 Back Case Replacement: 6 단계, 이미지 1/1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  7. Olympus Pen E-PL7 Back Case Replacement: 7 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  8. Olympus Pen E-PL7 Back Case Replacement: 8 단계, 이미지 1/1
    • Remove the lens mount with tweezers.
  9. Olympus Pen E-PL7 Back Case Replacement: 9 단계, 이미지 1/1
    • Use tweezers to remove the inner metal ring.
  10. Olympus Pen E-PL7 Back Case Replacement: 10 단계, 이미지 1/2 Olympus Pen E-PL7 Back Case Replacement: 10 단계, 이미지 2/2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  11. Olympus Pen E-PL7 Back Case Replacement: 11 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  12. Olympus Pen E-PL7 Back Case Replacement: 12 단계, 이미지 1/1
    • Remove the two 4 mm Phillips screws.
  13. Olympus Pen E-PL7 Back Case Replacement: 13 단계, 이미지 1/3 Olympus Pen E-PL7 Back Case Replacement: 13 단계, 이미지 2/3 Olympus Pen E-PL7 Back Case Replacement: 13 단계, 이미지 3/3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  14. Olympus Pen E-PL7 Back Case Replacement: 14 단계, 이미지 1/3 Olympus Pen E-PL7 Back Case Replacement: 14 단계, 이미지 2/3 Olympus Pen E-PL7 Back Case Replacement: 14 단계, 이미지 3/3
    • Use tweezers to remove the metal clip from the external flash mount.
  15. Olympus Pen E-PL7 Back Case Replacement: 15 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  16. Olympus Pen E-PL7 Back Case Replacement: 16 단계, 이미지 1/2 Olympus Pen E-PL7 Back Case Replacement: 16 단계, 이미지 2/2
    • Remove the second external flash clip with tweezers.
  17. Olympus Pen E-PL7 Back Case Replacement: 17 단계, 이미지 1/2 Olympus Pen E-PL7 Back Case Replacement: 17 단계, 이미지 2/2
    • Remove the external flash port casing to expose five more screws.
  18. Olympus Pen E-PL7 Back Case Replacement: 18 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  19. Olympus Pen E-PL7 Back Case Replacement: 19 단계, 이미지 1/1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  20. Olympus Pen E-PL7 Back Case Replacement: 20 단계, 이미지 1/1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  21. Olympus Pen E-PL7 Back Case Replacement: 21 단계, 이미지 1/3 Olympus Pen E-PL7 Back Case Replacement: 21 단계, 이미지 2/3 Olympus Pen E-PL7 Back Case Replacement: 21 단계, 이미지 3/3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  22. Olympus Pen E-PL7 Back Case Replacement: 22 단계, 이미지 1/3 Olympus Pen E-PL7 Back Case Replacement: 22 단계, 이미지 2/3 Olympus Pen E-PL7 Back Case Replacement: 22 단계, 이미지 3/3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kelsea Weber
회원 가입일: 11/12/15
19,166 평판
안내서 32개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,709개 작성하였습니다
댓글 한 개
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 41
전체 시간: 2,853
