소개
Use this guide to replace a damaged back case, or open the case to access other components of your camera.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
필요한 것
Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - 답글
