주요 콘텐츠로 건너뛰기
Olympus Pen E-PL7 LCD Screen Replacement
필요한 것
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Olympus Pen E-PL7 LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Olympus Pen E-PL7 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Olympus Pen E-PL7 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 Olympus Pen E-PL7 LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Olympus Pen E-PL7 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the LCD Screen.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kelsea Weber
회원 가입일: 11/12/15
21,030 평판
안내서 32개를 작성함
10가이드 댓글
Magnifico
Great Work!!
apuntotres - 답글
Where can I buy a replacement LCD screen?
Joshua Almeida - 답글
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - 답글
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - 답글
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 34
지난 30일: 154
전체 시간: 12,390
