주요 콘텐츠로 건너뛰기
Olympus SP-320 Back casing and LCD screen Replacement
필요한 것
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: 1 단계, 이미지 1/3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: 1 단계, 이미지 2/3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: 1 단계, 이미지 3/3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: 2 단계, 이미지 1/1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: 3 단계, 이미지 1/1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: 4 단계, 이미지 1/3 Olympus SP-320 Back casing and LCD screen Replacement: 4 단계, 이미지 2/3 Olympus SP-320 Back casing and LCD screen Replacement: 4 단계, 이미지 3/3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: 5 단계, 이미지 1/3 Olympus SP-320 Back casing and LCD screen Replacement: 5 단계, 이미지 2/3 Olympus SP-320 Back casing and LCD screen Replacement: 5 단계, 이미지 3/3
    • You have detached the back casing and LCD screen.
결론
Brenna McCullough
회원 가입일: 09/15/16
409 평판
안내서 3개 작성하였습니다
University of North Texas, Team 1-5, Campbell Fall 2016 University of North Texas, Team 1-5, Campbell Fall 2016 회원
UNT-CAMPBELL-F16S1G5
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 536
