주요 콘텐츠로 건너뛰기
Olympus SP-320 Motherboard Replacement
필요한 것
  1. Olympus SP-320 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Olympus SP-320 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Olympus SP-320 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: 3 단계, 이미지 1/2 Olympus SP-320 Motherboard Replacement: 3 단계, 이미지 2/2
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: 4 단계, 이미지 1/3 Olympus SP-320 Motherboard Replacement: 4 단계, 이미지 2/3 Olympus SP-320 Motherboard Replacement: 4 단계, 이미지 3/3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: 5 단계, 이미지 1/2 Olympus SP-320 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brenna McCullough
회원 가입일: 09/15/16
409 평판
안내서 3개 작성하였습니다
University of North Texas, Team 1-5, Campbell Fall 2016 University of North Texas, Team 1-5, Campbell Fall 2016 회원
UNT-CAMPBELL-F16S1G5
2 회원들
안내서 6개 작성하였습니다
댓글 2개
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - 답글
It would be nice to know why you needed to access the motherboard.
John - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 539
