이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
Remove the three Phillips #00 screws from the front of the camera.
Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
Using a plastic spudger, lift up the black clips.
Still using the plastic spudger, detach the gold connector strip and white connector strip.
Using both hands, pull the camera apart into two pieces.
Unscrew the screws. (6 screws)( photo shows 7 screws -editorial comment)
다른 2명이 해당 안내서를 완성하였습니다.
