주요 콘텐츠로 건너뛰기
Olympus Stylus 1030 SW Camera Disassembly
필요한 것
  1. Olympus Stylus 1030 SW Camera Disassembly, Olympus Stylus 1030 SW Camera Disassembly: 1 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly, Olympus Stylus 1030 SW Camera Disassembly: 1 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly, Olympus Stylus 1030 SW Camera Disassembly: 1 단계, 이미지 3/3
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW Camera Disassembly: 2 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 2 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 2 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW Camera Disassembly: 3 단계, 이미지 1/2 Olympus Stylus 1030 SW Camera Disassembly: 3 단계, 이미지 2/2
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW Camera Disassembly: 4 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 4 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 4 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW Camera Disassembly: 5 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 5 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 5 단계, 이미지 3/3
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW Camera Disassembly: 6 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 6 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 6 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW Camera Disassembly: 7 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 7 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 7 단계, 이미지 3/3
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW Camera Disassembly: 8 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 8 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 8 단계, 이미지 3/3
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW Camera Disassembly: 9 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 9 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 9 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW Camera Disassembly: 10 단계, 이미지 1/2 Olympus Stylus 1030 SW Camera Disassembly: 10 단계, 이미지 2/2
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW Camera Disassembly: 11 단계, 이미지 1/3 Olympus Stylus 1030 SW Camera Disassembly: 11 단계, 이미지 2/3 Olympus Stylus 1030 SW Camera Disassembly: 11 단계, 이미지 3/3
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
결론
Shanmei Zheng
회원 가입일: 02/17/14
304 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 2,702
