주요 콘텐츠로 건너뛰기
Olympus Stylus 1030 SW Flash Assembly Replacement
필요한 것
  1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 3개 중 3개
    • Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
    • Lift up on the plate until it comes off the rest of the camera.
  2. Olympus Stylus 1030 SW Flash Assembly Replacement: 2 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 2 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the two screws on both of the side plates of the camera.
  3. Olympus Stylus 1030 SW Flash Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera.
  4. Olympus Stylus 1030 SW Flash Assembly Replacement: 4 단계, 이미지 2개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Turn the camera so the short side without the av port is facing you.
    • Remove both of the screws on this side using the Phillips #00 screwdriver.
    • Remove the front case.
  5. Olympus Stylus 1030 SW Flash Assembly Replacement: 5 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 5 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
    • Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
    • Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
  6. Olympus Stylus 1030 SW Flash Assembly Replacement: 6 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 6 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Open the battery door and use your Phillips #00 screwdriver to remove the screw in the middle of the opening.
    • Use the spudger to pry at the rear case until it comes off.
  7. Olympus Stylus 1030 SW Flash Assembly Replacement: 7 단계, 이미지 2개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the camera so the front is facing you.
    • Use your Phillips #00 screwdriver to remove the three screws located in the corners on this side.
  8. Olympus Stylus 1030 SW Flash Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Turn the camera so you are looking at the top.
    • Use your Phillips #00 screwdriver to remove the single screw.
  9. Olympus Stylus 1030 SW Flash Assembly Replacement: 9 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 9 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Use your spudger to gently pry at the side of the LCD screen and the cover over it.
    • Gently take it apart, using caution with the motherboard and battery.
  10. Olympus Stylus 1030 SW Flash Assembly Replacement: 10 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 10 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement: 10 단계, 이미지 3개 중 3개
    • Use your Phillips #00 screwdriver to remove the three screws.
  11. Olympus Stylus 1030 SW Flash Assembly Replacement: 11 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 11 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Flash Assembly Replacement: 11 단계, 이미지 3개 중 3개
  12. Olympus Stylus 1030 SW Flash Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the foam to the side gently and use your Phillips #00 screwdriver to remove the single screw.
  13. Olympus Stylus 1030 SW Flash Assembly Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use your tweezers to gently pull the motherboard out of the camera.
  14. Olympus Stylus 1030 SW Flash Assembly Replacement: 14 단계, 이미지 2개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Use your Phillips #00 screwdriver to remove the two screws holding the wires to the flash assembly.
  15. Olympus Stylus 1030 SW Flash Assembly Replacement: 15 단계, 이미지 2개 중 1개 Olympus Stylus 1030 SW Flash Assembly Replacement: 15 단계, 이미지 2개 중 2개
    • Use your tweezers to gently remove the last wires connected to the flash assembly.
결론
작성자
2다른 기여자 명과 함께
Paige Asmus
회원 가입일: 03/24/23
241 평판
안내서 1개를 작성함
Casper College, Team 1-4, Lareau Spring 2023 Casper College, Team 1-4, Lareau Spring 2023 회원
CASC-LAREAU-S23S1G4
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 79
