부품
부품은 필요하지 않습니다.
Remove the top three T6 screws of the front panel using a 1.5 mm screwdriver.
Remove the three screws on the side of the lens using a Phillips #00 screwdriver.
Remove the two black speaker screws shown in red circles in the first image using a Phillips #00 screwdriver.
After unscrewing the screws from the previous step, lift out the speaker plate when it becomes loose enough.
Open the multi-connector cover shown in the yellow square in the fourth image.
The side panel that covers the multi-connector and the speaker can be detached by sliding the side panel off of the device.
Open the AV port door.
Unscrew the four corner screws that hold the front and back halves of the casing together using a Phillips #00 screwdriver.
Release the top holding clip using a plastic spudger or a fingernail.
Slowly unfold the front and back halves of the camera to expose the electrical ribbons.
Pivot the black plastic strip up using a plastic opening tool and a pair of tweezers. This will lock the wide copper ribbon in place.
Once the black plastic strip releases the wide copper ribbon, detach the wide copper ribbon using a thumb or a pair of tweezers.
The front and back halves of the device can be separated once all three ribbons are disconnected.
