주요 콘텐츠로 건너뛰기
Olympus Stylus 1030 SW Rear Case Replacement
필요한 것
  1. Olympus Stylus 1030 SW Rear Case Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Rear Case Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Rear Case Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Start by removing the front case of the Olympus Stylus 1030 SW.
    • Use a Phillips #00 screwdriver to unscrew the three screws.
    • Once all three screws are removed, take your hand to remove the front case from the camera. You will lift until it is fully off.
  2. Olympus Stylus 1030 SW Rear Case Replacement: 2 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Rear Case Replacement: 2 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Rear Case Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the screws from the side panel.
    • Use a Phillips #00 screwdriver to remove both of the screws from the battery door.
  3. Olympus Stylus 1030 SW Rear Case Replacement: 3 단계, 이미지 2개 중 1개 Olympus Stylus 1030 SW Rear Case Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
    • Use a Phillips #00 screwdriver to remove both screws.
  4. Olympus Stylus 1030 SW Rear Case Replacement: 4 단계, 이미지 2개 중 1개 Olympus Stylus 1030 SW Rear Case Replacement: 4 단계, 이미지 2개 중 2개
    • Now flip your camera with the rear side facing away from you. Remove both Phillips #00 screws.
    • You should now be able to remove the front case.
  5. Olympus Stylus 1030 SW Rear Case Replacement: 5 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Rear Case Replacement: 5 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Rear Case Replacement: 5 단계, 이미지 3개 중 3개
    • To remove the rear case of the camera, start with the rear end facing away from you.
    • Remove the two Phillips #00 screws.
    • Then flip the camera to the front facing you.
    • Remove the single Phillips #0 screw.
  6. Olympus Stylus 1030 SW Rear Case Replacement: 6 단계, 이미지 3개 중 1개 Olympus Stylus 1030 SW Rear Case Replacement: 6 단계, 이미지 3개 중 2개 Olympus Stylus 1030 SW Rear Case Replacement: 6 단계, 이미지 3개 중 3개
    • Now place your camera right side up with the front facing you.
    • Open the battery door and locate the screw placed in the middle.
    • Remove the Phillips #00 screw.
    • You now take your spatula to separate the rear case from the camera.
결론
작성자
3다른 기여자 명과 함께
Alexis Sulzle
회원 가입일: 03/24/23
301 평판
안내서 2개를 작성함
Casper College, Team 1-4, Lareau Spring 2023 Casper College, Team 1-4, Lareau Spring 2023 회원
CASC-LAREAU-S23S1G4
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 164
