메인 콘텐츠로 스킵하기
소개
If the flash on your Olympus Stylus 410 no longer works, use this guide to replace it.
부품
지정된 부품이 없습니다.
  1. Locate the 2 screws on the bottom of the slider.
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Gently pull on the bottom of the slider until it comes off the lower track.
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Lift the slider up until it comes off the upper track.
    • Lift the slider up until it comes off the upper track.
  4. The slider should now be free from the body of the camera.
    • The slider should now be free from the body of the camera.
  5. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Use the spudger to peel off the outer metal band, starting from the bottom of the camera. The metal band it attached to the camera with glue in addition to screws.  Be careful not to bend the band when removing it from the camera.
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. The shutter button can now be removed. It is not connected to the camera and can be lifted off. The shutter button can now be removed. It is not connected to the camera and can be lifted off.
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Remove the memory card. Locate and remove the 2 screws using a #00 Phillips screwdriver.
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Use a spudger around the edge of the case to loosen it. Carefully wiggle the back case off. This may require a fair amount of force. Carefully wiggle the back case off. This may require a fair amount of force.
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required. Be careful not to completely pull the front case off because it will still be connected with wires.
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Locate the gray compartment covering the flash. Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
    • Locate the gray compartment covering the flash.
    • Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
    • Gently lift the tab so the gray compartment becomes free.
  13. Use the spudger around the perimeter of the gray compartment to detach it from the front case. The gray compartment can now be removed from the flash unit. The flash unit can now be removed, and a new one soldered back on.
    • Use the spudger around the perimeter of the gray compartment to detach it from the front case.
    • The gray compartment can now be removed from the flash unit.
    • The flash unit can now be removed, and a new one soldered back on.
결론
Rory Aronson
회원 가입일: 2010년 04월 15일
34 평판
안내서 6개 작성하였습니다
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 회원
CPSU-MANESS-S10S6G13
5 회원들
안내서 9개 작성하였습니다
Good instructions, but author doesn't say where or how to get new flash unit!
Ken Arnoldi
ken arnoldi - 답글
Good instructions but author doesn't say how or where to get new flash unit!
ken arnoldi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,768
