주요 콘텐츠로 건너뛰기
Olympus Stylus 725 SW LCD Screen Replacement
필요한 것
  1. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: 1 단계, 이미지 2개 중 1개 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: 1 단계, 이미지 2개 중 2개
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 2 단계, 이미지 3개 중 1개 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 2 단계, 이미지 3개 중 2개 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 2 단계, 이미지 3개 중 3개
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Olympus Stylus 725 SW LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Olympus Stylus 725 SW LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  4. Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 1개 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 2개 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3개 중 3개
    • Remove the screws in the back panel using a Phillips #00 screwdriver.
    • Detach the ribbon cables that connect the LCD to the back panel of the camera.
  5. Olympus Stylus 725 SW LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Olympus Stylus 725 SW LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Bobby Hodges
회원 가입일: 04/18/10
49 평판
안내서 6개를 작성함
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G71
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 8,292
