주요 콘텐츠로 건너뛰기
Olympus Stylus 725 SW Lens Replacement
필요한 것
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 1 단계, 이미지 1/3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 1 단계, 이미지 2/3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 1 단계, 이미지 3/3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  2. Olympus Stylus 725 SW Lens Replacement: 2 단계, 이미지 1/2 Olympus Stylus 725 SW Lens Replacement: 2 단계, 이미지 2/2
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: 3 단계, 이미지 1/3 Olympus Stylus 725 SW Lens Replacement, Front Panel: 3 단계, 이미지 2/3 Olympus Stylus 725 SW Lens Replacement, Front Panel: 3 단계, 이미지 3/3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: 4 단계, 이미지 1/3 Olympus Stylus 725 SW Lens Replacement, Side Panels: 4 단계, 이미지 2/3 Olympus Stylus 725 SW Lens Replacement, Side Panels: 4 단계, 이미지 3/3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  5. Olympus Stylus 725 SW Lens Replacement: 5 단계, 이미지 1/3 Olympus Stylus 725 SW Lens Replacement: 5 단계, 이미지 2/3 Olympus Stylus 725 SW Lens Replacement: 5 단계, 이미지 3/3
    • After removing all four of the screws, pry the side covers off of the camera.
  6. Olympus Stylus 725 SW Lens Replacement, Lens: 6 단계, 이미지 1/3 Olympus Stylus 725 SW Lens Replacement, Lens: 6 단계, 이미지 2/3 Olympus Stylus 725 SW Lens Replacement, Lens: 6 단계, 이미지 3/3
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
  7. Olympus Stylus 725 SW Lens Replacement: 7 단계, 이미지 1/3 Olympus Stylus 725 SW Lens Replacement: 7 단계, 이미지 2/3 Olympus Stylus 725 SW Lens Replacement: 7 단계, 이미지 3/3
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
  8. Olympus Stylus 725 SW Lens Replacement: 8 단계, 이미지 1/2 Olympus Stylus 725 SW Lens Replacement: 8 단계, 이미지 2/2
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
결론
Bobby Hodges
회원 가입일: 04/18/10
49 평판
안내서 6개 작성하였습니다
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G71
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 4,437
