주요 콘텐츠로 건너뛰기
Olympus Stylus 760 Case Replacement
필요한 것
  1. Olympus Stylus 760 Case Replacement, Case: 1 단계, 이미지 1/1
    • Remove the 2 screws from the bottom of the camera
  2. Olympus Stylus 760 Case Replacement: 2 단계, 이미지 1/1
    • Remove the screw from the right side of the camera.
  3. Olympus Stylus 760 Case Replacement: 3 단계, 이미지 1/1
    • Remove the two screws from the left side of the camera
  4. Olympus Stylus 760 Case Replacement: 4 단계, 이미지 1/3 Olympus Stylus 760 Case Replacement: 4 단계, 이미지 2/3 Olympus Stylus 760 Case Replacement: 4 단계, 이미지 3/3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  5. Olympus Stylus 760 Case Replacement: 5 단계, 이미지 1/2 Olympus Stylus 760 Case Replacement: 5 단계, 이미지 2/2
    • Pull the silver bracket and buttons off of the camera
  6. Olympus Stylus 760 Case Replacement: 6 단계, 이미지 1/3 Olympus Stylus 760 Case Replacement: 6 단계, 이미지 2/3 Olympus Stylus 760 Case Replacement: 6 단계, 이미지 3/3
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screws on the left side of the camera.
    • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  7. Olympus Stylus 760 Case Replacement: 7 단계, 이미지 1/1
    • Flip up clip on circuit ribbon, carefully
    • Detach the ribbon from the rear to the front and pull it out, gently.
  8. Olympus Stylus 760 Case Replacement: 8 단계, 이미지 1/1
    • You will be left with four major pieces
결론
Tracy Donovan
회원 가입일: 02/10/12
13 평판
안내서 1개 작성함
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012 회원
JMU-KLEIN-S12S3G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 587
