주요 콘텐츠로 건너뛰기
Olympus Stylus 760 LCD Screen Replacement
필요한 것
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: 1 단계, 이미지 1/1
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: 2 단계, 이미지 1/1
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: 3 단계, 이미지 1/1
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/1
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: 7 단계, 이미지 1/3 Olympus Stylus 760 LCD Screen Replacement: 7 단계, 이미지 2/3 Olympus Stylus 760 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: 8 단계, 이미지 1/2 Olympus Stylus 760 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: 9 단계, 이미지 1/3 Olympus Stylus 760 LCD Screen Replacement: 9 단계, 이미지 2/3 Olympus Stylus 760 LCD Screen Replacement: 9 단계, 이미지 3/3
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: 10 단계, 이미지 1/1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: 11 단계, 이미지 1/2 Olympus Stylus 760 LCD Screen Replacement: 11 단계, 이미지 2/2
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: 12 단계, 이미지 1/2 Olympus Stylus 760 LCD Screen Replacement: 12 단계, 이미지 2/2
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: 13 단계, 이미지 1/1
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Cosgrove
회원 가입일: 02/10/12
39 평판
안내서 1개 작성함
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012 회원
JMU-KLEIN-S12S3G3
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
from where i can get repaired u760 camera
tahir zafar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 1,508
