주요 콘텐츠로 건너뛰기
Olympus Stylus Tough 6020 LCD Replacement
필요한 것
  1. Olympus Stylus Tough 6020 LCD Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 LCD Replacement, Bottom Plating: 2 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, Bottom Plating: 2 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 LCD Replacement, Bottom Plating: 2 단계, 이미지 3개 중 3개
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 LCD Replacement, Top Plating: 3 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, Top Plating: 3 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 LCD Replacement, Top Plating: 3 단계, 이미지 3개 중 3개
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 LCD Replacement, Left Plating: 4 단계, 이미지 2개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, Left Plating: 4 단계, 이미지 2개 중 2개
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 LCD Replacement, Black "Olympus" Face Plate: 5 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, Black "Olympus" Face Plate: 5 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 LCD Replacement, Black "Olympus" Face Plate: 5 단계, 이미지 3개 중 3개
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 LCD Replacement, End Casing: 6 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, End Casing: 6 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 LCD Replacement, End Casing: 6 단계, 이미지 3개 중 3개
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 LCD Replacement, Blue Face Plate: 7 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, Blue Face Plate: 7 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 LCD Replacement, Blue Face Plate: 7 단계, 이미지 3개 중 3개
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 LCD Replacement, Back Plate: 8 단계, 이미지 1개 중 1개
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 LCD Replacement: 9 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 LCD Replacement: 9 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 LCD Replacement: 9 단계, 이미지 3개 중 3개
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 LCD Replacement, Ribbon Cables: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, pull the white ribbon cable to disconnect it.
    • Using tweezers, pull the brown ribbon cable to disconnect it.
  11. Olympus Stylus Tough 6020 LCD Replacement, LCD Screen: 11 단계, 이미지 2개 중 1개 Olympus Stylus Tough 6020 LCD Replacement, LCD Screen: 11 단계, 이미지 2개 중 2개
    • Using the Phillips #00 Screwdriver, unscrew the 3.9mm screws on the back left side of the LCD screen case.
    • Using the spudger, gently pry the two screw holders from the LCD screen case.
    • Using your hands, gently push LCD through the LCD screen case.
결론
작성자
6다른 기여자 명과 함께
Luke Wiley
회원 가입일: 04/08/15
263 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 23
전체 시간: 1,095
