주요 콘텐츠로 건너뛰기
Olympus Stylus Tough 6020 Lens Replacement
필요한 것
  1. Olympus Stylus Tough 6020 Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: 2 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: 2 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: 2 단계, 이미지 3개 중 3개
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 Lens Replacement, Top Plating: 3 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 Lens Replacement, Top Plating: 3 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 Lens Replacement, Top Plating: 3 단계, 이미지 3개 중 3개
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 Lens Replacement, Left Plating: 4 단계, 이미지 2개 중 1개 Olympus Stylus Tough 6020 Lens Replacement, Left Plating: 4 단계, 이미지 2개 중 2개
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: 5 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: 5 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: 5 단계, 이미지 3개 중 3개
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 Lens Replacement, End Casing: 6 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 Lens Replacement, End Casing: 6 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 Lens Replacement, End Casing: 6 단계, 이미지 3개 중 3개
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: 7 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: 7 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: 7 단계, 이미지 3개 중 3개
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 Lens Replacement, Back Plate: 8 단계, 이미지 1개 중 1개
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 Lens Replacement: 9 단계, 이미지 3개 중 1개 Olympus Stylus Tough 6020 Lens Replacement: 9 단계, 이미지 3개 중 2개 Olympus Stylus Tough 6020 Lens Replacement: 9 단계, 이미지 3개 중 3개
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 Lens Replacement, Lens: 10 단계, 이미지 1개 중 1개
    • Unscrew screws on place holder plates
  11. Olympus Stylus Tough 6020 Lens Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift Lens compartment out of device.
  12. Olympus Stylus Tough 6020 Lens Replacement: 12 단계, 이미지 1개 중 1개
    • From top view, unscrew 3 screws
    • Do not worry about the screw on top of the 2 screws.
  13. Olympus Stylus Tough 6020 Lens Replacement: 13 단계, 이미지 2개 중 1개 Olympus Stylus Tough 6020 Lens Replacement: 13 단계, 이미지 2개 중 2개
    • Lens comes off
결론
작성자
4다른 기여자 명과 함께
Violeta
회원 가입일: 04/08/15
101 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 728
