주요 콘텐츠로 건너뛰기
Olympus Stylus Tough 6020 Shutter Button Replacement
필요한 것
  1. Olympus Stylus Tough 6020 Shutter Button Replacement, Shutter Button: 1 단계, 이미지 1/3 Olympus Stylus Tough 6020 Shutter Button Replacement, Shutter Button: 1 단계, 이미지 2/3 Olympus Stylus Tough 6020 Shutter Button Replacement, Shutter Button: 1 단계, 이미지 3/3
    • Turn the camera so that you are looking at the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
    • Using your fingers, pull off the shutter button.
    • You may need to use a spudger to pry off the shutter button.
결론
Taylor Carabin
회원 가입일: 04/15/15
259 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 405
