주요 콘텐츠로 건너뛰기
Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement
필요한 것
  1. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: 1 단계, 이미지 1/3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: 1 단계, 이미지 2/3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: 1 단계, 이미지 3/3
    • Locate the battery/card cover on the bottom of the camera. .
    • Slide the tab labeled lock to show orange.
    • Slide the battery/card cover lock to revile orange and the door will spring open.
  2. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 2 단계, 이미지 1/3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 2 단계, 이미지 2/3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 2 단계, 이미지 3/3
    • Remove the 2 Phillips #00 screws on the inner battery door.
    • Use a spudger to release the seal and metal clip.
    • Replace the seal.
  3. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 3 단계, 이미지 1/2 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 3 단계, 이미지 2/2
    • Locate the connector cover on the side of the camera.
    • Slide the connector cover lock to revile orange and the door will spring open.
  4. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 4 단계, 이미지 1/3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 4 단계, 이미지 2/3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 4 단계, 이미지 3/3
    • Remove the 2 Phillips #00 screws on the inner connector door.
    • Use a spudger to release the seal, the clear plastic piece, and the metal piece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amanda
회원 가입일: 07/20/15
933 평판
안내서 8개 작성하였습니다
댓글 3개
Where can I get the seals?
Ahmed - 답글
I have the same question. Where can I buy the seals? Olymus service man told me it is not possible to buy, and that I have to send TG-2 to service and pay about 100$.
adan - 답글
OK. Great instructions. I think I could do this, but where do I get the seals?
Steve Tobin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 19
전체 시간: 2,056
