주요 콘텐츠로 건너뛰기
Olympus Stylus Tough-6000 Lens Cover Replacement
필요한 것
  1. Olympus Stylus Tough-6000 Lens Cover Replacement, Disassemble Camera.: 1 단계, 이미지 1/1
    • You will want to disassemble the camera to get to the Lens Cover.
  2. Olympus Stylus Tough-6000 Lens Cover Replacement: 2 단계, 이미지 1/1
    • There are two screws on the right side of the camera.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Olympus Stylus Tough-6000 Lens Cover Replacement: 3 단계, 이미지 1/1
    • On the left side of the camera there will be another set of screws.
    • Unscrew both screws with the same Phillips #00 screwdriver.
  4. Olympus Stylus Tough-6000 Lens Cover Replacement: 4 단계, 이미지 1/1
    • After unscrewing the screws on the left side of the camera you will notice a speaker hat.
    • You will be able to pull the speaker hat off.
    • You must pull the speaker hat off to be able to pry the front shell of the camera apart.
  5. Olympus Stylus Tough-6000 Lens Cover Replacement: 5 단계, 이미지 1/1
    • Grab your plastic opening tool and begin to pry off the front shell of the camera.
    • The front shell will easily come off after a couple of prys.
  6. Olympus Stylus Tough-6000 Lens Cover Replacement: 6 단계, 이미지 1/1
    • Once you have the camera shell cover off you can see the lens cover.
    • Unscrew the lens cover with your Phillips #00 screwdriver to replace it with a new lens cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shannon Cooney
회원 가입일: 01/15/15
355 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 1,101
