주요 콘텐츠로 건너뛰기
Olympus Stylus Tough-6000 On/Off Button Replacement
필요한 것
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: 1 단계, 이미지 1개 중 1개
    • First sit the camera on its bottom. You will be working on the on/off button.
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: 2 단계, 이미지 1개 중 1개
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: 3 단계, 이미지 1개 중 1개
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: 4 단계, 이미지 1개 중 1개
    • Grab your plastic opening tool and start prying off the panel.
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: 5 단계, 이미지 1개 중 1개
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: 6 단계, 이미지 1개 중 1개
    • You have reached the on/off button.
    • You can now replace it!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Shannon Cooney
회원 가입일: 01/15/15
355 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G1
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 647
