주요 콘텐츠로 건너뛰기
Olympus Stylus Tough-8010 Side Panel Replacement
필요한 것
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: 1 단계, 이미지 3개 중 1개 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: 1 단계, 이미지 3개 중 2개 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: 1 단계, 이미지 3개 중 3개
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: 2 단계, 이미지 3개 중 1개 Olympus Stylus Tough-8010 Side Panel Replacement: 2 단계, 이미지 3개 중 2개 Olympus Stylus Tough-8010 Side Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: 3 단계, 이미지 3개 중 1개 Olympus Stylus Tough-8010 Side Panel Replacement: 3 단계, 이미지 3개 중 2개 Olympus Stylus Tough-8010 Side Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: 4 단계, 이미지 2개 중 1개 Olympus Stylus Tough-8010 Side Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: 5 단계, 이미지 3개 중 1개 Olympus Stylus Tough-8010 Side Panel Replacement: 5 단계, 이미지 3개 중 2개 Olympus Stylus Tough-8010 Side Panel Replacement: 5 단계, 이미지 3개 중 3개
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
결론
작성자
4다른 기여자 명과 함께
James G Payne
회원 가입일: 03/23/15
225 평판
안내서 2개를 작성함
Baylor, Team 7-15, Williams Spring 2015 Baylor, Team 7-15, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G15
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 3
전체 시간: 377
