주요 콘텐츠로 건너뛰기
Olympus TG-820 iHS Battery Replacement
  1. Olympus TG-820 iHS Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Battery Replacement: 2 단계, 이미지 3개 중 1개 Olympus TG-820 iHS Battery Replacement: 2 단계, 이미지 3개 중 2개 Olympus TG-820 iHS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Battery Replacement: 3 단계, 이미지 2개 중 1개 Olympus TG-820 iHS Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
결론
작성자
1다른 기여자 명과 함께
Leslie Cade
회원 가입일: 03/21/16
343 평판
안내서 3개를 작성함
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016 회원
CLEM-BENSON-S16S7G2
4 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 663
