주요 콘텐츠로 건너뛰기
Olympus TG-820 iHS LCD Screen Replacement
필요한 것
  1. Olympus TG-820 iHS LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Olympus TG-820 iHS LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS LCD Screen Replacement, Back Case: 4 단계, 이미지 1개 중 1개
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Olympus TG-820 iHS LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Olympus TG-820 iHS LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Olympus TG-820 iHS LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove face plate.
  8. Olympus TG-820 iHS LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 Olympus TG-820 iHS LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Olympus TG-820 iHS LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 Olympus TG-820 iHS LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Olympus TG-820 iHS LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Olympus TG-820 iHS LCD Screen Replacement: 11 단계, 이미지 3개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 11 단계, 이미지 3개 중 2개 Olympus TG-820 iHS LCD Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
  12. Olympus TG-820 iHS LCD Screen Replacement, LCD Screen: 12 단계, 이미지 1개 중 1개
    • Now that ribbons are detached, orient plate as shown.
    • Remove the four black 2mm Phillips #00 screws.
  13. Olympus TG-820 iHS LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 Olympus TG-820 iHS LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the six silver 3mm Phillips #00 screws.
    • Remove the last top 3.25mm Phillips #00 screw.
  14. Olympus TG-820 iHS LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Using the black nylon spudger, pry out the metal plate.
    • This metal plate is the LCD component needing to be replaced
결론
작성자
3다른 기여자 명과 함께
Leslie Cade
회원 가입일: 03/21/16
343 평판
안내서 3개를 작성함
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016 회원
CLEM-BENSON-S16S7G2
4 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 3,430
