주요 콘텐츠로 건너뛰기
Olympus TG-820 iHS Locking Mechanism Replacement
필요한 것
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: 2 단계, 이미지 3개 중 1개 Olympus TG-820 iHS Locking Mechanism Replacement: 2 단계, 이미지 3개 중 2개 Olympus TG-820 iHS Locking Mechanism Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: 3 단계, 이미지 2개 중 1개 Olympus TG-820 iHS Locking Mechanism Replacement: 3 단계, 이미지 2개 중 2개
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: 4 단계, 이미지 3개 중 1개 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: 4 단계, 이미지 3개 중 2개 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: 4 단계, 이미지 3개 중 3개
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: 5 단계, 이미지 1개 중 1개
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: 6 단계, 이미지 2개 중 1개 Olympus TG-820 iHS Locking Mechanism Replacement: 6 단계, 이미지 2개 중 2개
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
결론
작성자
2다른 기여자 명과 함께
Larissa Knight
회원 가입일: 03/21/16
549 평판
안내서 5개를 작성함
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016 회원
CLEM-BENSON-S16S7G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 616
