소개
Have you tried all the other manuals and still can't figure out what is wrong with your camera? Try replacing the motherboard by following these steps.
필요한 것
Orient the camera so you are looking at the bottom.
Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
이 단계에 사용된 도구:Tweezers$4.99
Remove the four 3mm Phillips #000 screws.
Use tweezers to remove metal plate
There is now full access to the motherboard which you can replace components on by soldering.
거의 끝나갑니다!
결론
