주요 콘텐츠로 건너뛰기
Olympus Tough TG-1 Battery Replacement
  1. Olympus Tough TG-1 Battery Replacement, Battery Removal: 1 단계, 이미지 1/1
    • Release both latches on the battery compartment on the bottom of the camera to open the door.
  2. Olympus Tough TG-1 Battery Replacement: 2 단계, 이미지 1/1
    • After you have removed the latch, open the compartment door to remove the battery.
    • The batteries contain highly acidic contents. If the battery has leaked or ruptured while inside the compartment, there may be damage to the camera's circuitry. Carefully clean out any residue from the battery using latex gloves and tissues.
    • If the compartment door is loose, check the hinge or the locking pieces under the rubber pad. To do this, unscrew and remove the rubber and metal plate on the door.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Richard Yacobellis
회원 가입일: 01/21/15
225 평판
안내서 2개 작성하였습니다
USF Tampa, Team 4-6, Brown Winter 2015 USF Tampa, Team 4-6, Brown Winter 2015 회원
USFT-BROWN-W15S4G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 15
전체 시간: 1,019
