주요 콘텐츠로 건너뛰기
Olympus VR-350 Back Plate Replacement
필요한 것
  1. Olympus VR-350 Back Plate Replacement, Front Plate: 1 단계, 이미지 1/2 Olympus VR-350 Back Plate Replacement, Front Plate: 1 단계, 이미지 2/2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Back Plate Replacement: 2 단계, 이미지 1/1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Back Plate Replacement: 3 단계, 이미지 1/3 Olympus VR-350 Back Plate Replacement: 3 단계, 이미지 2/3 Olympus VR-350 Back Plate Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Back Plate Replacement, Back Plate: 4 단계, 이미지 1/2 Olympus VR-350 Back Plate Replacement, Back Plate: 4 단계, 이미지 2/2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
결론
Adri
회원 가입일: 02/23/15
456 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 730
