주요 콘텐츠로 건너뛰기
Olympus VR-350 Lens Box Unit Replacement
필요한 것
  1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: 1 단계, 이미지 1/2 Olympus VR-350 Lens Box Unit Replacement, Front Plate: 1 단계, 이미지 2/2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Lens Box Unit Replacement: 2 단계, 이미지 1/1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Lens Box Unit Replacement: 3 단계, 이미지 1/3 Olympus VR-350 Lens Box Unit Replacement: 3 단계, 이미지 2/3 Olympus VR-350 Lens Box Unit Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Lens Box Unit Replacement, Back Plate: 4 단계, 이미지 1/2 Olympus VR-350 Lens Box Unit Replacement, Back Plate: 4 단계, 이미지 2/2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: 5 단계, 이미지 1/2 Olympus VR-350 Lens Box Unit Replacement, LCD Screen: 5 단계, 이미지 2/2
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
  6. Olympus VR-350 Lens Box Unit Replacement: 6 단계, 이미지 1/1
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
  7. Olympus VR-350 Lens Box Unit Replacement: 7 단계, 이미지 1/1
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
  8. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: 8 단계, 이미지 1/1
    • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
  9. Olympus VR-350 Lens Box Unit Replacement: 9 단계, 이미지 1/2 Olympus VR-350 Lens Box Unit Replacement: 9 단계, 이미지 2/2
    • Remove the orange ribbon cable from the connector on the left side of the motherboard.
    • To do this, gently lift up the small grey clasp and pull the cable ribbon.
  10. Olympus VR-350 Lens Box Unit Replacement: 10 단계, 이미지 1/1
    • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
    • You may need to use force to pull out the ribbon cables.
  11. Olympus VR-350 Lens Box Unit Replacement: 11 단계, 이미지 1/1
    • Pull the lens box up and out to remove it.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Brooke
회원 가입일: 02/23/15
278 평판
안내서 1개 작성함
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 15
전체 시간: 1,492
