주요 콘텐츠로 건너뛰기
Olympus VR-350 Power Button Replacement
필요한 것
  1. Olympus VR-350 Power Button Replacement, Front Plate: 1 단계, 이미지 2개 중 1개 Olympus VR-350 Power Button Replacement, Front Plate: 1 단계, 이미지 2개 중 2개
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Power Button Replacement: 3 단계, 이미지 3개 중 1개 Olympus VR-350 Power Button Replacement: 3 단계, 이미지 3개 중 2개 Olympus VR-350 Power Button Replacement: 3 단계, 이미지 3개 중 3개
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Power Button Replacement, Back Plate: 4 단계, 이미지 2개 중 1개 Olympus VR-350 Power Button Replacement, Back Plate: 4 단계, 이미지 2개 중 2개
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Power Button Replacement, Power Button: 5 단계, 이미지 2개 중 1개 Olympus VR-350 Power Button Replacement, Power Button: 5 단계, 이미지 2개 중 2개
    • Remove the silver panel from the top of the camera.
  6. Olympus VR-350 Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Flip the silver panel over. The power button is the smaller button covered by a metal backing.
  7. Olympus VR-350 Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the metal backing away from the silver panel.
  8. Olympus VR-350 Power Button Replacement: 8 단계, 이미지 1개 중 1개
    • Push the power button down and out of the silver panel with your finger.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adri
회원 가입일: 02/23/15
456 평판
안내서 3개를 작성함
USF Tampa, Team 1-3, Leahy Winter 2015 USF Tampa, Team 1-3, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 1,691
