주요 콘텐츠로 건너뛰기
Omaker M4 Battery Replacement
필요한 것
  1. Omaker M4 Battery Replacement, Back Case: 1 단계, 이미지 1/1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: 2 단계, 이미지 1/2 Omaker M4 Battery Replacement: 2 단계, 이미지 2/2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: 3 단계, 이미지 1/2 Omaker M4 Battery Replacement: 3 단계, 이미지 2/2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: 4 단계, 이미지 1/1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: 5 단계, 이미지 1/2 Omaker M4 Battery Replacement: 5 단계, 이미지 2/2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: 6 단계, 이미지 1/3 Omaker M4 Battery Replacement, Battery: 6 단계, 이미지 2/3 Omaker M4 Battery Replacement, Battery: 6 단계, 이미지 3/3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Carlos Pernia
회원 가입일: 02/10/16
170 평판
안내서 1개 작성함
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
What battery is required for this though? Is it easily found on amazon?
Mohsin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 1,329
