소개
When using the metal spudger to remove the battery, be sure to carefully pry along the entire side the battery so that the battery will come off without bending.
필요한 것
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
다른 3명이 해당 안내서를 완성하였습니다.
