주요 콘텐츠로 건너뛰기
Omaker M4 Port Cover Replacement
필요한 것
  1. Omaker M4 Port Cover Replacement, Back Case: 1 단계, 이미지 1/1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: 2 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 2 단계, 이미지 2/2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: 3 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 3 단계, 이미지 2/2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: 4 단계, 이미지 1/1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: 5 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 5 단계, 이미지 2/2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: 6 단계, 이미지 1/2 Omaker M4 Port Cover Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: 7 단계, 이미지 1/1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: 8 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 8 단계, 이미지 2/2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: 9 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 9 단계, 이미지 2/2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: 10 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 10 단계, 이미지 2/2
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: 11 단계, 이미지 1/2 Omaker M4 Port Cover Replacement, Port Cover: 11 단계, 이미지 2/2
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: 12 단계, 이미지 1/1
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: 13 단계, 이미지 1/2 Omaker M4 Port Cover Replacement: 13 단계, 이미지 2/2
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: 14 단계, 이미지 1/1
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Obaida Matar
회원 가입일: 02/17/16
119 평판
안내서 1개 작성함
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 365
