주요 콘텐츠로 건너뛰기
Onda VI10 Battery Replacement
필요한 것
  1. Onda VI10  Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Use a number 0 screw driver to remove the four screws.
  2. Onda VI10  Battery Replacement: 2 단계, 이미지 1/1
    • Power Button on the side should be pointing outward.
    • Note: This is so the ribbon cables are not damaged.
  3. Onda VI10  Battery Replacement: 3 단계, 이미지 1/1
    • Heat up the back of the device with a hair dryer to loosen the glue.
  4. Onda VI10  Battery Replacement: 4 단계, 이미지 1/1
    • Pry up battery from plastic using a nylon spudger or plastic opening tool.
  5. Onda VI10  Battery Replacement: 5 단계, 이미지 1/1
    • Desolder the two battery cables from the mother board.
결론
Clint Richards
회원 가입일: 03/22/17
101 평판
안내서 1개 작성함
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi ! Thx for the tuto !
Were can i shop thé battery ?! Please ? I live in France...
mauriciano67 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 13
전체 시간: 667
