주요 콘텐츠로 건너뛰기
Onda VI10 Screen Replacement
필요한 것
  1. Onda VI10  Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Remove four Phillips head screws from back with #0 screw driver.
  2. Onda VI10  Screen Replacement: 2 단계, 이미지 1/2 Onda VI10  Screen Replacement: 2 단계, 이미지 2/2
    • Separate the back from the screen and open as shown. Make sure to open from the side with the power button to avoid damaging the ribbon cables.
  3. Onda VI10  Screen Replacement: 3 단계, 이미지 1/1
    • Using the plastic spudger, lift the black latches for the ribbon cables and slide the cables out of their sockets. Now the two halves can be separated.
  4. Onda VI10  Screen Replacement: 4 단계, 이미지 1/1
    • There are 14 3mm long screws surrounding the screen. Using the #00 Phillips screwdriver, remove all of these screws.
  5. Onda VI10  Screen Replacement: 5 단계, 이미지 1/1
    • Using the metal spudger, depress the four plastic tabs to free the glass from the display.
  6. Onda VI10  Screen Replacement: 6 단계, 이미지 1/1
    • Use the metal spudger again to get between the glass and the chrome trim ring. Lightly pry the glass away from the display. If this proves difficult, double check that all of the screws have been removed and that all four plastic clips are pushed in. Again, start from the side opposite the ribbon cable to avoid damaging it.
  7. Onda VI10  Screen Replacement: 7 단계, 이미지 1/1
    • Once the glass and display have been separated, pull the glass away from the display and carefully slide the ribbon cable out of the display housing.
결론
Solomon Hunter
회원 가입일: 03/08/17
101 평판
안내서 1개 작성함
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 275
