주요 콘텐츠로 건너뛰기
Onda VI10 Speaker Replacement
필요한 것
  1. Onda VI10 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Use a number 0 screw driver to remove the four screws.
  2. Onda VI10 Speaker Replacement: 2 단계, 이미지 1/1
    • Power Button on the side should be pointing outward.
    • Note: This is so the ribbon cables inside are not damaged.
  3. Onda VI10 Speaker Replacement: 3 단계, 이미지 1/1
    • Locate the black and red speaker wires going back to the mother board.
    • Note: Speaker wires may run underneath the battery wires.
  4. Onda VI10 Speaker Replacement: 4 단계, 이미지 1/1
    • Carefully remove the speaker cables from the retaining tabs using a thin metal spudger.
  5. Onda VI10 Speaker Replacement: 5 단계, 이미지 1/1
    • Pry the speaker out of its molding using a thin metal spudger
  6. Onda VI10 Speaker Replacement: 6 단계, 이미지 1/1
    • Desolder the two speaker wires from the motherboard using a soldering iron.
    • Caution: Soldering Iron is extremely hot.
결론
Carlos Diaz
회원 가입일: 03/08/17
101 평판
안내서 1개 작성함
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 148
