주요 콘텐츠로 건너뛰기
One Education Infinity Keyboard Replacement
필요한 것
  1. One Education Infinity Keyboard Replacement, Back Case: 1 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement, Back Case: 1 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Keyboard Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Keyboard Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Keyboard Replacement, Battery: 4 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement, Battery: 4 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Keyboard Replacement: 5 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement: 5 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Keyboard Replacement, Keyboard: 6 단계, 이미지 2개 중 1개 One Education Infinity Keyboard Replacement, Keyboard: 6 단계, 이미지 2개 중 2개
    • Remove the two silver 3.5 mm screws from the two raised mounting points with a Phillips #00 screwdriver.
  7. One Education Infinity Keyboard Replacement: 7 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement: 7 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Using a spudger, pop up the locking hinge on the wide ZIF connector in the middle of the back case on the right side of the motherboard.
    • Pull the wide ribbon cable out from the ZIF connector with your fingers.
  8. One Education Infinity Keyboard Replacement: 8 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement: 8 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • Use a spudger to pry the keyboard up from one of the upper corners, then move the spudger along the upper edge to disconnect all of the clips on the upper side.
    • Do not remove the keyboard yet, as the ribbon cable on the backside is still held down with tape.
    • Flip the device over without allowing the keyboard clips to reengage.
  9. One Education Infinity Keyboard Replacement: 9 단계, 이미지 3개 중 1개 One Education Infinity Keyboard Replacement: 9 단계, 이미지 3개 중 2개 One Education Infinity Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Peel back the thick black tape holding down the keyboard ribbon cable.
    • Lift up the ribbon cable and feed it through the case as you pull the keyboard away.
    • You may need to move the tape out of the way as you insert the new keyboard ribbon cable.
  10. One Education Infinity Keyboard Replacement: 10 단계, 이미지 2개 중 1개 One Education Infinity Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Taking care that the ribbon cable doesn't get caught on the tape on the other side, lift the keyboard out from the upper case.
결론
작성자
1다른 기여자 명과 함께
Austin Blakely
회원 가입일: 03/11/19
22,277 평판
안내서 53개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,781개를 작성함
1가이드 댓글
Some of the keys in my keyboard are not working. should i get it repaired or should i buy a new keyboard since i am a fast typing person and i am not liking it when the keys stops responding
Slayer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 267
