주요 콘텐츠로 건너뛰기
One Education Infinity Touchpad Replacement
필요한 것
  1. One Education Infinity Touchpad Replacement, Back Case: 1 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement, Back Case: 1 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Touchpad Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Touchpad Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Touchpad Replacement: 5 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement: 5 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Touchpad Replacement, Solid State Drive: 6 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement, Solid State Drive: 6 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement, Solid State Drive: 6 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Touchpad Replacement: 7 단계, 이미지 3개 중 1개 One Education Infinity Touchpad Replacement: 7 단계, 이미지 3개 중 2개 One Education Infinity Touchpad Replacement: 7 단계, 이미지 3개 중 3개
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
  8. One Education Infinity Touchpad Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
    • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
  9. One Education Infinity Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
  10. One Education Infinity Touchpad Replacement: 10 단계, 이미지 1개 중 1개
    • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
  11. One Education Infinity Touchpad Replacement: 11 단계, 이미지 1개 중 1개
    • Using your fingers, carefully unplug the two speaker wires from the motherboard.
  12. One Education Infinity Touchpad Replacement: 12 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 12 단계, 이미지 2개 중 2개
    • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
  13. One Education Infinity Touchpad Replacement: 13 단계, 이미지 1개 중 1개
    • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
  14. One Education Infinity Touchpad Replacement: 14 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 14 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
    • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
    • Using your fingers, carefully lift the motherboard out of the internal panel.
  15. One Education Infinity Touchpad Replacement, Touchpad: 15 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
  16. One Education Infinity Touchpad Replacement: 16 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 16 단계, 이미지 2개 중 2개
    • Peel back the black tape.
    • Using your fingers, carefully lift the metal plate out of the internal panel.
  17. One Education Infinity Touchpad Replacement: 17 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the two 2mm silver screws.
  18. One Education Infinity Touchpad Replacement: 18 단계, 이미지 2개 중 1개 One Education Infinity Touchpad Replacement: 18 단계, 이미지 2개 중 2개
    • Using your fingers, carefully lift the touch-pad out of the internal panel.
결론
작성자
5다른 기여자 명과 함께
Jason Childers
회원 가입일: 10/10/19
109 평판
안내서 1개를 작성함
Cal Poly, Team S11-G4, Regan Fall 2019 Cal Poly, Team S11-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S11G4
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 13
전체 시간: 375
