주요 콘텐츠로 건너뛰기
One Education Infinity Webcam Replacement
필요한 것
  1. One Education Infinity Webcam Replacement, Back Case: 1 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement, Back Case: 1 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Webcam Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity Webcam Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Webcam Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Webcam Replacement, Battery: 4 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement, Battery: 4 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Webcam Replacement: 5 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement: 5 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement: 5 단계, 이미지 3개 중 3개
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Webcam Replacement, Upper Case: 6 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement, Upper Case: 6 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement, Upper Case: 6 단계, 이미지 3개 중 3개
    • Flip open the laptop so that the screen is exposed.
    • We found it convenient to flip the laptop into tablet mode for added support.
    • Using a spudger, remove the six screw covers along the bezel of the screen.
  7. One Education Infinity Webcam Replacement: 7 단계, 이미지 2개 중 1개 One Education Infinity Webcam Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the six 2.8 mm Phillips #00 screws along the bezel.
  8. One Education Infinity Webcam Replacement: 8 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement: 8 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement: 8 단계, 이미지 3개 중 3개
    • Use the two tabs on the top edge of the screen to pry the case apart.
    • Once the two top clips have been disengaged, start to work your way around the rest of the screen.
  9. One Education Infinity Webcam Replacement: 9 단계, 이미지 1개 중 1개
    • Once all the clips have been popped off, remove the upper case from the back of the display assembly.
    • You may want to close the laptop while disconnecting the hinge-side edge, as it will give you extra clearance for the upper case.
  10. One Education Infinity Webcam Replacement, Webcam: 10 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement, Webcam: 10 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement, Webcam: 10 단계, 이미지 3개 중 3개
    • Remove the two 3.3 mm Phillips #00 screws holding down the webcam mount.
    • Peel off the two pieces of tape holding down the webcam wire just to the left of the webcam.
  11. One Education Infinity Webcam Replacement: 11 단계, 이미지 2개 중 1개 One Education Infinity Webcam Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the silver 2.7 mm screw from the circuit board beside the webcam with a Phillips #00 screwdriver.
  12. One Education Infinity Webcam Replacement: 12 단계, 이미지 3개 중 1개 One Education Infinity Webcam Replacement: 12 단계, 이미지 3개 중 2개 One Education Infinity Webcam Replacement: 12 단계, 이미지 3개 중 3개
    • Unplug the webcam cable from the circuit board by pulling it horizontally from its connector.
  13. One Education Infinity Webcam Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the webcam up from the upper case assembly to remove.
결론
Austin Blakely
회원 가입일: 03/11/19
22,274 평판
안내서 53개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,765개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 158
