주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide is a prerequisite demonstrating how to disconnect the antenna connection to the motherboard in the One Education Infinity:One laptop.
부품
지정된 부품이 없습니다.
  1. Use a spudger to disconnect the black bundled cable connector from the motherboard. Use a spudger to disconnect the black bundled cable connector from the motherboard.
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. Use a spudger to lift the black tab on top of the ZIF connector. Slide the ribbon cable out of the connector. Slide the ribbon cable out of the connector.
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  4. Use a spudger to flip up the black retaining flap on the ZIF connector. Pull the folded ribbon cable straight out of the connector. This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. Use a spudger to pry the battery away from the device.
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  6. Use ESD safe tweezers to disconnect the antenna from the motherboard. Use ESD safe tweezers to disconnect the antenna from the motherboard.
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
결론
Taylor Bratsch
회원 가입일: 2016년 09월 06일
4,284 평판
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 32
