주요 콘텐츠로 건너뛰기
One Education Infinity:One Battery Replacement
필요한 것
  1. One Education Infinity:One Battery Replacement, Top Case: 1 단계, 이미지 3개 중 1개 One Education Infinity:One Battery Replacement, Top Case: 1 단계, 이미지 3개 중 2개 One Education Infinity:One Battery Replacement, Top Case: 1 단계, 이미지 3개 중 3개
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 One Education Infinity:One Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity:One Battery Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity:One Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: 4 단계, 이미지 3개 중 1개 One Education Infinity:One Battery Replacement: 4 단계, 이미지 3개 중 2개 One Education Infinity:One Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Taylor Bratsch
회원 가입일: 09/06/16
6,083 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,130
